Cam advice....
The FRR E303 is a pretty mild cam that doesn't loose a lot of bottom end torque. The bumpity-bump idle is greatly affected by compression. The higher the compression the more "blow back" you get during valve overlap causing the exhaust note.
I believe if you spend enough time planning the right combination of pieces, you can get a nice sounding idle and great offroad power.
Thanks for the info. Are you volunteering? I don't know jack about this stuff. All my engines have always been stock. This engine, stock, should have 9.0:1 compression.
I don't mind helping. Before I built the 393W for my rig (in snipes243 now) I had a plan for a 302 with pretty much stock heads and bottom end that should pump out about 300ftlbs of torque from 2k-5k. And it would have a wicked idle. Not sure if that is the direction you want or not.
[Image: DecktopDyno302stockheads.jpg]
That is what I am going for. That is some sweet torque values in the low range. Any way the mid range HP can me moved down about 500-1000 RPM? Is this the FRR E303?
That is my "secret weapon" cam. The particular simulation was a flat tappet cam with EB heads. I'll tinker with some different cam grinds and see what we can come up with. BTW...That engine would be more of a "Welch" style engine meant to be driven with the balls out.
Also if I remember correctly, the engine that used to be in Carl's burgundy Bronco was a late model roller with Trick Flow heads and cam. Turn up the volume and watch the video...
Carl's hill climb
bucketobolts Wrote:That is my "secret weapon" cam. The particular simulation was a flat tappet cam with EB heads. I'll tinker with some different cam grinds and see what we can come up with. BTW...That engine would be more of a "Welch" style engine meant to be driven with the balls out.
Carl's hill climb
DAYUM THAT SOUNDS SWEEEEET!!!!:clap:
Now THAT is what I am talking about!!!
Here are a few charts for a .030 over 10:1 short block with stock E7 casting heads and roller cams. I looked up the Comp 266HR, B303, E303, Stage 1 Trick Flow, and Comp XE270HR. All should have a little bump to the idle with the exception of the 266HR, but should work with a stock converter.
I like the torque curve of both the B303 and the E303. The XE270 made more horsepower, but looks like it may be lacking below 2k rpm.
Comp266HR
[Image: 302E7266HR.jpg]
Trick Flow Stage 1
[Image: 302E7Stg1TrickFlow.jpg]
B303
[Image: 302E7B303.jpg]
E303
[Image: 302E7E303.jpg]
Comp XE270HR
[Image: 302E7XE270HR.jpg]
this is starting to sound like our 306, however the cam aint that impressive...more like a RV cam. I think Shawn's mustang 306 has a e303 cam in it...sounds sweet
http://www.youtube.com/watch?v=VNwO4Fo6QLM
correction, shawn just told me its a wolverine which is close to the F303 about .510-.512 lift, a e303 is about .498 lift
I think the E303 or the Comp XE270HR would be the best choices from this list considering the HP and torque levels. Again, I am running a stock 302HO with an unknown time and mileage since rebuild (if any). Jdowns brought a valid point to the table about throwing the engine over the edge with performance upgrades. Does anyone else hae any further thoughts on that subject?
  What to do advice Phoneman 5 3,351 05-14-2014, 05:56 PM
Last Post: Phoneman
  A little advice rancej 5 2,033 03-19-2011, 11:53 PM
Last Post: rancej
  Need Advice on 351W Headers 73Bronc 9 3,786 10-15-2009, 12:04 PM
Last Post: wormhole
  Need advice on tube flaring problem... chuzie 8 1,970 08-28-2009, 05:42 PM
Last Post: 66stocker
  power steering set up advice ?????? broncomania 6 5,563 04-09-2009, 06:44 PM
  need some parts and advice offshorecorley 1 3,195 12-03-2008, 08:21 PM
Last Post: offshorecorley
  Engine build advice cuz1 6 1,852 06-27-2008, 05:35 PM
  NEED SOME ADVICE PLEASE DUCKWORTH71/76 24 8,547 06-17-2008, 10:28 PM
  Need some advice johnpaulgolf 31 8,675 05-27-2008, 09:06 PM
