Cam advice....
#31
I was not sure which Trick Flow heads your running, so I used the High Port flow #'s with 2.02/1.80 valves. If your running a different set up I can modify it with no problems. But that combo seems to be a pretty good one. Looks like it makes just under 400HP and almost 400FtLbs of torque from 3-5K.
[Image: Chucks306.jpg]
wow, thats not bad...ill see if i can get the actual list of parts, maybe you wouldnt mind doing one more for me when i get the info? Thanks Aaron!!!!!
heres a quick run down, just talked to Jeff(PO)
'95 truck block true roller
stock crank(balanced and polished)
stock rods w/ARP bolts
trick flow roller cam/roller lifters
Crane 1.6 roller rockers
performer RPM alum intake
Probe forged domed pistons w/ plasma moly rings
block bored .30 over plus .01 over for NOS
trick flow twisted street head 2.02/1.60
ARP head studs
TCI torque converter 1000rpm stall over stock
  What to do advice Phoneman 5 3,352 05-14-2014, 05:56 PM
Last Post: Phoneman
  A little advice rancej 5 2,033 03-19-2011, 11:53 PM
Last Post: rancej
  Need Advice on 351W Headers 73Bronc 9 3,789 10-15-2009, 12:04 PM
Last Post: wormhole
  Need advice on tube flaring problem... chuzie 8 1,975 08-28-2009, 05:42 PM
Last Post: 66stocker
  power steering set up advice ?????? broncomania 6 5,566 04-09-2009, 06:44 PM
  need some parts and advice offshorecorley 1 3,196 12-03-2008, 08:21 PM
Last Post: offshorecorley
  Engine build advice cuz1 6 1,858 06-27-2008, 05:35 PM
  NEED SOME ADVICE PLEASE DUCKWORTH71/76 24 8,561 06-17-2008, 10:28 PM
  Need some advice johnpaulgolf 31 8,691 05-27-2008, 09:06 PM
