Power Steering issues
Thx Ben and Charles! I have a fella coming down from NC to buy the 5 aluminum rims I posted on Classic so I can use that money to buy the proper brackets, hose and v-groove pulley. I've dealt with one guy at Wild Horses and he may give me another deal if I buy all those items from them.
sounds like a plan!
Nick @ WHs came thru with a discount but man shipping has gotten high. I got the shiney, silver brackets with plenty of hardware today. The saginaw pump came yesterday. So here is my problem, I tried to mate the pump with the bracket and I can only get one hole to line up??? Do I need to modify the bracket a little (at the pencil point)? Any suggestions would be helpful!
Here are two pics of the front and rear of my saginaw pump. Yes I even dumbed it up for me with the colored pens/ pencils! I want to make sure which bolt will alow me to "clock" or rotate the PS pump. I really want to make sure I do not ruin this pump!
i dont believe you can clock that pump, thos bolts go through that housing and into the pump. i could be wrong, but i dont see how that will work. as for the bracket...yes, modify it. you look like you have a lil different style pump housing...vs the ole can ham look. will the pump and bracket not fit under the hood as they sit now? why clock it?
blazinchuck Wrote:i dont believe you can clock that pump, thos bolts go through that housing and into the pump. i could be wrong, but i dont see how that will work. as for the bracket...yes, modify it. you look like you have a lil different style pump housing...vs the ole can ham look. will the pump and bracket not fit under the hood as they sit now? why clock it?
Hey Chuck, I spoke with the fella that rebuilt my pump and he said my pump has a bigger reservoir b/c of the dual return. He said "most" single returns fit this particular bracket. No big deal I can mill out a slot next week. I have not installed it on the motor yet but it should fit well below the hood. I read on a Colorado Bronco website where a guy clocked/ rotated his but it must have been a single return. I don't even know how much truth it is to clocking a single return, only so much faith you can get from some people's threads! Confusedcratchhe:
By next week I hope my WH PS Saginaw bracket will look like BC's PS Saginaw bracket. Notice the notch, hmmmmmm.
I finished "modifying" the PS bracket. I fitted all up and works well on the bench. It appears I took out more than I needed to but oh well. I made a sleeve that goes b/ the 7/16ths rod/ screw and the 1/2" hole, works very well. All I need to do now ismake some spacers.
Today is my day off so I installed the pulley on the pump. Wasn't too bad with the right tools. Next bolted the bracket to the pump. With a lil bit of time and sweat I was able to bolt all the brackets up. The PS pulley and crank pulley lined up good, just gotta get a smaller v-belt.
so when do we get to see this beast on the road? Or TRAIL?? Great progress keep it up
  Heim Steering wepuckett 20 4,559 08-28-2015, 03:18 PM
  Steering box help snipes243 24 12,390 07-17-2015, 09:42 AM
  What type Power Steering Cooler are you all using? Broncitis 7 2,029 07-16-2015, 01:32 AM
  Steering shaft Extension Question??? Broncitis 4 2,866 04-17-2015, 02:27 PM
  motor issues please help!! bigredbronco 9 2,071 12-22-2012, 11:30 AM
Last Post: bigredbronco
  351 issues gumby93 18 6,353 09-29-2012, 07:30 PM
  Quick disconnect steering wheel snipes243 4 3,714 08-21-2012, 06:50 PM
  Home made heavy duty steering Timstrk 4 2,798 11-25-2010, 10:47 AM
  power steering pumps snipes243 9 4,900 11-15-2010, 05:17 PM
Last Post: nhopman
  Dana 44 Power-Lock jdowns67 2 981 09-26-2010, 10:18 PM
