motor issues please help!!
She has no problem starting but once I put it in drive she stuggles and cuts off. cant even get more than 5 feet. just redid the timing but it didnt help
What year and type of motor and transmission
82 351. I think this is its 3rd motor and the transmission only has like 5k miles on it
So carb and C6?
What is your idle set at?
How long has this been going on?
Any recent changes other than the timing?
What did you set the timing to?
Can you keep it running with a little extra throttle?
I have additional question depending on EFI or carb and auto or manual trans response.
its got an eddlebrock carb. it idles at 800 and stays there it only happens when I try to go somewhere. it got this bad a couple days ago and i havent messed with it since. only thing i have done other than the timing is a new alt. i set the timing so the light matched up and no matter how much throttle i give it it sounds like its starving and dies. its an auto. I would have more info about it but ive only had it for a month and a half
So in park or neutral, you can punch the throttle and it runs fine? This issue only occurs when you place it in gear?
I am inclined to say you have a carb issue(s) perhaps vacuum kick, fast idle cam index, or fast idle RPM adjustment.
It happens when I do it in park/neutral but only sometimes. you think maybe my jets are clogged? Or could it be a filter
I bet the sometimes parts is dependent on engine temp. If you have a clogged jet or filter, it would stall out in Park/Neutral as well when you punch the throttle.
Check out a tech manual for procedures to set the aforementioned parameters.
shall do. I tried letting it heat up. when its cold it idles at 2k but all i have t do is just kick the gas and it settles at 800
  Which Motor Should I Use? obxbronco 7 2,308 02-24-2016, 10:01 PM
Last Post: obxbronco
  motor help!!!!! broncatron 6 4,282 07-09-2013, 10:03 PM
Last Post: broncatron
  351 issues gumby93 18 7,090 09-29-2012, 07:30 PM
  Blown Motor. NateMob 22 7,771 11-02-2011, 09:26 PM
Last Post: NateMob
  Specs for 351W motor mount bolts? 73Bronc 11 3,433 09-27-2011, 11:36 PM
Last Post: 73Bronc
  Power Steering issues Crawdad 31 6,640 07-28-2011, 09:29 PM
  Wheel hop issues JustJeff 2 1,884 01-25-2010, 01:53 AM
Last Post: JustJeff
  Swapped the motor in my Centurion and added a turbo! smooth 4 1,939 12-11-2009, 01:43 PM
  Transfer Case Issues Pup 2 2,596 08-28-2009, 06:59 PM
Last Post: Pup
  Motor Mount locations JayT 8 2,205 08-19-2009, 01:09 AM
