recent upgrades and repairs thread
I know you're not really into fullsizes chuck but the shifter hole is uphill from where the water puddles. On the 78 79's you got rot through holes real bad near the back humps behind the seats and near the outer front corners of the dirvers floor pan. It is very important to get that water to drain out through the door and elsewhere.
The Trucks
[Image: img_0041.2.jpg]
The Kompany Kool AKKountant
Nice work "Angel" keep us posted. Confusedupergrin:
see in my world we just drill more holes:gunshot:redneck style:hysterical:
What does that matting run in terms of $$$?
It is a butyl mix typically called various names but referred to as "peel and seal". $50 bucks at home depot or lowes for a very large roll in the roofing department.
Literally peel and stick. I cut sections for sound deadening behind door panels, rear panels, etc...
The Trucks
I tried something similar once in my rig. The coating bubbled and peeled after a few months because of all the moisture. Probably because I used the wrong stuff.
blazinchuck Wrote:see in my world we just drill more holes:gunshot:redneck style:hysterical:
More holes = Faster H2O drainage :xyxthumbs:
I plan on drilling holes also :rockon:...as soon as I firgure out where my water sits :eyecrazy:...That was the plan from the start bedliner :bigsquaregrin:/pressure washer :muscle:/drain holes :bdent:
Confusedcratchhe:
:gunshot:
chuzie Wrote:I tried something similar once in my rig. The coating bubbled and peeled after a few months because of all the moisture. Probably because I used the wrong stuff.
Which coating? Mine is all meant to get wet. Very wet. The butyl stuff is made for house roofs. The sound deadener/undercoating is meant for the bottom of trucks. The Dupont stuff that is $7.49 a can. I went through over 10 cans. Then covered it with roofing butyl Big Grin Half of the project has been done for a year with no issues or bad spots. All I can say is spend way too much time in preperation and you'll never regret it. I do a once over with alcohol about 10 minutes before painting to remove as much moisture as possible from the surface. (that is of course after all prep work). I had just been too busy to get the other half done and glad I have found time lately. I hate having my rig down.
The Trucks
johnpaulgolf Wrote:I plan on drilling holes also :rockon:...as soon as I firgure out where my water sits :eyecrazy:...That was the plan from the start bedliner :bigsquaregrin:/pressure washer :muscle:/drain holes :bdent:
Confusedcratchhe:
:gunshot:
There are drain holes in the 78 broncos, but they are just not strategically placed. :error:
I'll be helping that out too, just have to finish
this prep work in the ares I do not want water sitting :beer:
The Trucks
  Broncitis Rat Rod build thread. Broncitis 121 29,326 04-01-2016, 10:53 PM
  My 76 repairs. BucknEB 30 5,722 08-29-2011, 04:12 PM
  5.0 EFI upgrades? blazinchuck 4 1,422 07-25-2011, 10:57 PM
Last Post: nhopman
  Front D44 Ring/Pinion and upgrades scbronco 17 2,944 12-31-2010, 10:07 PM
  Lisa's '77 Upgrades blazinchuck 22 3,741 12-29-2010, 01:37 PM
  Stock 66 interior rebuild thread 66stocker 37 11,125 04-03-2010, 11:07 AM
Last Post: 66stocker
  The Roll Cage Thread johnski 4 3,882 10-30-2007, 09:50 PM
