steering wheel question
hey guys whats going on. i recently installed a new steering gear box on the bronco last week and was wondering why i still have play in the steering wheel. i thought by putting in a new box that the play would go away. also whenever i make a turn,the wheel does not straighten out by its self. is there something i forgot to do or do i need to check on something else.
Check your ball joints and tie rod ends. These parts can have play in them also. Jack the front of the truck up and have someone turn the wheel slowly left and right. See if anything not your steering box moves.
Tim
Do you have any lift? Sounds like your castor may be out also. That will keep the wheel from returning after a turn. Also check the track rod bushings and mounts. If they are loose they will make the front end sloppy also.
i have a 6in lift with a 2in body lift.
check your track bar bushings, f-150s & broncos are famous for these wearing out....:rubeyes:
http://www.wheelindixie.com
i sure will. thanks.
  Heim Steering wepuckett 20 9,624 08-28-2015, 03:18 PM
  Steering box help snipes243 24 17,930 07-17-2015, 09:42 AM
  What type Power Steering Cooler are you all using? Broncitis 7 4,187 07-16-2015, 01:32 AM
  Steering shaft Extension Question??? Broncitis 4 4,689 04-17-2015, 02:27 PM
  Exhaust question Casey835 27 15,168 08-16-2013, 06:03 PM
  Quick disconnect steering wheel snipes243 4 5,467 08-21-2012, 06:50 PM
  1991 351W EFI Question Crawdad 4 3,933 03-27-2012, 09:05 AM
  Hard top Question 744x4 5 6,209 09-06-2011, 10:32 PM
Last Post: Mill Knob
  Tire question dixieboyz13 12 7,891 08-25-2011, 01:58 PM
Last Post: ncsubronc
  Fiberglass Dr Insert Question 744x4 5 3,746 08-10-2011, 01:24 PM
Last Post: dixieboyz13
