10-17-2009, 11:14 AM
Anybody used something other than new or Jeep?
Fold & Tumble Rear Seat
10-18-2009, 11:27 AM
I read on Classic about guys using the rear seats from mini vans.
Then when you get ready to mount it, you can use Unistrut to make tracks in the bed area. There are spring loaded nuts for the strut to make the seat adjustable or removable. My friend Justin, goes by JKrieg70 on ClassicBroncos, used this method in his Bronco. It really made the back seat area flexible.
10-18-2009, 11:33 AM
There is a junkyard thread on classic that has an Isuzu seat that is almost direct bolt in. I'll go look and if I find it I'll add the link later.
10-18-2009, 11:35 AM
Deluxe split bench seat from an Isuzu pickup, again a bolt into the Bronco (half the bolt holes line up!!)
Thread on Classic with a lot of other junkyard scores :xyxthumbs:
10-18-2009, 10:28 PM
Thanks for the info. The junkyard thread looks real good.
| 1977 Ford Bronco rear ended 9" rebuild | Crawdad | 10 | 9,007 |
01-19-2017, 12:53 PM Last Post: snipes243 |
| Rebuilding used rear leaf springs | Crawdad | 5 | 6,472 |
12-12-2016, 11:54 AM Last Post: Crawdad |
| Lighted rear view mirror | chuzie | 6 | 7,682 |
06-20-2015, 12:18 AM Last Post: chuzie |
| rear main seal | snipes243 | 5 | 5,007 |
05-03-2014, 11:45 AM Last Post: chuzie |
| stock rear drums | scbronco | 11 | 5,773 |
03-06-2014, 08:09 PM Last Post: Bronco Biff |
| Late 70s Cadi rear disc brakes for 77 banjo rear end | Crawdad | 11 | 7,561 |
01-11-2014, 12:26 AM Last Post: Crawdad |
| 77 EB Rear Drive Shaft Dropped - Second time in six months | UTFLIWGYA | 4 | 4,129 |
12-01-2013, 10:38 PM Last Post: broncomatt |
| Grinding sound from rear end area when driving | Crawdad | 10 | 7,827 |
02-09-2013, 09:33 PM Last Post: blazinchuck |
| '94 351 Rear Main replacement | JayT | 5 | 3,804 |
12-22-2012, 05:34 PM Last Post: JayT |
| 5.0 rear main bearing... is it going out??? | chuzie | 16 | 8,256 |
12-18-2012, 04:52 PM Last Post: chuzie |
