C4 Trans. Cooler Fittings
Hello. I am bring back to life a 74 bronco. I installed the trans and need to order the fittings to get the cooler working. They appear to be 1/4? I ordered SS trans cooler lines from Jeff's. I do not have the orgional setup, so they will not work. Does anyone know what type of fittings to use? What type of trans cooling systems do you all use?
Thanks for all of your help.
ShepConfusedcratchhe:
im thinking you just need the threaded fittings that screw into the trans and then you screw your hoses to the fittings. you can get those at advance auto.
Those fittings broncomania is refering to are brass. They have a straight thread and an O ring. They adapt to a flared fitting on the hard lines. They should be in the HELP section of any Advance, AutoZone, Pepboys or O'Reilly's. If you can't find any local I have a few extras.
Thanks! I tried O'Reilly's without luck, so I will try the others today. Do you know what size? Thanks again for all of your help!
I'll go measure one in a minute.
The threads measure 3/8-24 and accept a 1/4" tube flare.
You are very helpful and thanks for taking the time. I will let you know how the project ends!
Thanks, Shep
I bought some bits last night, but have not installed them yet. Are they course or fine?
Thanks again, Shep
3/8-24 is fine thread.
Thanks. I think I found the right stuff at Mr. Gasket. I will let you know how everything turns out. Shep
  What type Power Steering Cooler are you all using? Broncitis 7 4,140 07-16-2015, 01:32 AM
  Automatic Trans: Why does the engine die as soon as I put it in Park or Neutral???? UTFLIWGYA 6 6,080 05-15-2014, 11:50 AM
Last Post: rbodine
  cummins to a ford small block standard trans adapter plate Rdnckdemo 2 2,504 04-14-2013, 01:19 AM
Last Post: Rdnckdemo
  C4 Trans Dipstick Tube SC74 5 4,908 10-24-2011, 01:35 PM
  Help identifying trans jdowns67 1 1,970 01-22-2011, 11:41 PM
  Please educate me on 3 speed trans RAT & RAN? Mill Knob 11 9,518 01-11-2011, 10:34 PM
Last Post: Mill Knob
  c4 trans filter change spring and thing! jrshepherd 2 3,631 03-13-2010, 08:12 PM
  Question: Trans lines and Gas tank jrshepherd 0 2,435 08-24-2009, 10:22 PM
  oil / PS cooler suggestions chuzie 6 5,482 12-25-2008, 10:34 PM
  Trans. Idea BigBird13 2 3,656 10-24-2008, 05:00 PM
Last Post: BigBird13
