Brad Howells 66 Build
Bought this 66 about two years ago as a resto project and an excuse to spend more time in the garage. Started to do some minor work on her and found out was going to be losing my job so all work stopped since last summer. Will be starting a new job in a few weeks so getting back into it.
First thing I did was remove about 3 inches of puddy on top of the upper cowl panel. Perviously owner said it was leaking a little under the dash on rainy days so he laid on the puddy. Found out there wasnt much metal left under the puddy (should have known). The bottem of the windshied mount panel had rotten away. In addition, the cluch pedal assembly where it bolts into the windshield mount panel had completety broken free. My cheap solution was to weld in a piece of angle iron which seemed to have worked.
Also put some gauges in the dash and repainted it.
Next going to weld in the RH upper cowl panel and a patch for the LH.
IMG]http://i984.photobucket.com/albums/ae322/BradHow/Post%201/1.jpg[/IMG]
[Image: 2.jpg]
[Image: 6.jpg]
[Image: 4.jpg]
[Image: 3.jpg]
[Image: 5.jpg]
[Image: 9.jpg]
[Image: 8.jpg]
[Image: 7.jpg]
[Image: 10.jpg]
[Image: 11.jpg]
Also need to have the 3 speed rebuilt, seems to have eaten itself while sitting this last year. Anybody recommend any good shops in Raleigh for this?
Nothing good ever develops from beneath putty but you seem to have found a cost effective solution to the problem.
back to the top...hows it going??
Just about finished with the patch panels. Taking longer than expected. Not pretty but learning how to weld as I go.
[Image: th_school046.jpg]
[Image: th_school083.jpg]
[Image: th_school082.jpg]
[Image: th_school049.jpg]
good job! learning to weld is a GREAT thing, your getting better and the panels look nice
Cut out old pass side floor pan. Sandblasted cross members and painted with por 15. Replace body mount under pan with new polyurethene from wild horses. Sprayed weld through primer on seams. Ready to be plug welded this week.
looking good. doing all that work is very time consuming, no matter who you are. keep it up!
  77 LUBR Build in SC, Part 2 Crawdad 79 61,523 04-20-2020, 12:57 PM
  ECORS Class A race rig build broncosbybart 387 162,572 10-29-2014, 05:33 PM
  1969 Bronco Build jtoney51 9 7,819 07-09-2013, 10:26 PM
  My 76 LUBR Build in SC Crawdad 177 70,316 05-14-2013, 07:13 PM
  DWB Build Thread DirtyWhiteBoy 33 18,015 12-30-2012, 09:14 PM
Last Post: DirtyWhiteBoy
  Welch Racing Build thread cuz1 183 70,753 11-03-2012, 08:04 PM
Last Post: Casey835
  my bronco build 66bronco 65 32,521 04-17-2012, 11:54 PM
Last Post: bigjake79
  Bighorn Build Thread Bighorn 70 33,027 11-16-2011, 05:33 PM
  JohnPaul's Build johnpaulgolf 303 141,561 11-16-2011, 10:52 AM
  JayT's lil 66 build JayT 30 15,787 11-01-2011, 09:06 PM
