rear main
so this might be a shot in the dark. can the rear main seal be replaced without pulling the engine. new to the 351m class...doin some research before i go deeper than i need to. all input is welcome! thanks asiel
pull the tranny. gotta pull something unfortunately
once u pull tranny it is a peice of cake...replaced mine when i first got it
I'm GUMBY DAM**T!!
The 351M should have a two piece rope-type seal. That means you need to drop the oil pan and remove the rear main cap. Then fish the upper half in to the block and the lower in to the cap.
They make a tool for this called the Sneaky Pete! x2 on the rear main cap and fishing the seal out.
It is a rubber 2 peice seal, sticks out of the block some and out of the main cap some. You can usualy push the seal out of the block with a peice of coat hanger. The main cap is easy.
You dont have too pull anything more than the oil pan, starter, maybe your y-pipe.
If the block side is hard to get out, loosen all the main bolts a few turns, takes the press off the seal. Besure to lube it good when you put it back in, and be very carefull to not peal any rubber off the seal as you push it in.
I actuly can give you some pics of what they look like apart as mine is on the stand still. If you feel that will help some.
thanks! pics are always nice to go by.i dont have to worry bout a y pipe because it has headers so after looking prolly just starter and oil pan! thanks guys.
Remember to properly re-torque the rear cap and any other main cap bolts that you loosen. Wasn't I, but I did see the aftermath once...
complete no more leaking from rear main! now just from valve cover...
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,099 01-19-2017, 12:53 PM
  Rebuilding used rear leaf springs Crawdad 5 6,534 12-12-2016, 11:54 AM
  Lighted rear view mirror chuzie 6 7,752 06-20-2015, 12:18 AM
  rear main seal snipes243 5 5,050 05-03-2014, 11:45 AM
  stock rear drums scbronco 11 5,864 03-06-2014, 08:09 PM
  Late 70s Cadi rear disc brakes for 77 banjo rear end Crawdad 11 7,631 01-11-2014, 12:26 AM
  77 EB Rear Drive Shaft Dropped - Second time in six months UTFLIWGYA 4 4,170 12-01-2013, 10:38 PM
  Grinding sound from rear end area when driving Crawdad 10 7,904 02-09-2013, 09:33 PM
  '94 351 Rear Main replacement JayT 5 3,846 12-22-2012, 05:34 PM
  5.0 rear main bearing... is it going out??? chuzie 16 8,380 12-18-2012, 04:52 PM
