this is how I trimmed 2" off of my rear fender
this is gonna be my attempt at a write up for the rear fender trim. When you trim the rear you have the problem of the wheel well is sandwiched with the out side of the truck so when you trim the fender it leaves a hole going into the cab. Here is how I did the trim and kept it semi closed up the pics are not gonna be all that great because some of them didn't come out right.
I started by laying out a line as a guide for my vertical cuts in the end this is where the new lip will be.
[Image: 1113.jpg]
then I cut the existing lip off
[Image: 1131.jpg]
[Image: 1132.jpg]
This is where the pics didn't make it
I then took my grinder with cut off wheels and made several cuts going from the edge of the fender up to the line that I drew creating many tabs this makes it easier to fold the metal.then you have to take the grinder and cut just the wheel well part that is glued to the fender once you cut that band out you can start to fold over the tabs as you get to the rear end of the fender you will need to take a hammer and knock some of the floor up because it is in the way. Once I got all the tabs bent over I used a bunch of 1/2" long zip screws and screwed the tabs up to the wheel well. By doing the tabs like this you will end up with some holes that I just ended up laying a bead of expanding foam around the new "SEAM" and after it dries just trim any that leaks out of the bottom.
[Image: 1127.jpg]
[Image: 1129.jpg]
Like I said the majority of the pictures didn't come out right but you should be able to take what I do have and get a good trim out of it.
here are some comparison pics
before
[Image: hhjjj003.jpg]
and after
[Image: 1135.jpg]
if you have any questions feel free to ask.
Good Work! You're getting handy at that body work Big Grin
I cringe!!! Smile
only the old guys cringe at the sound of cut metal but the young guys cringe when the metal is being bent by a rock because then they realize their dad is going to get ahold of them when they get home
I am ddaddy so I can dent it up all I want hahahahahaha besides trkbilder is the one with the restored b2 so that is why he cringes
I think I would cringe if someone put a scratch on his BII...thats gotta be the cleanest one around-period!
nice job-by the way!!!!
blazinchuck Wrote:I think I would cringe if someone put a scratch on his BII...thats gotta be the cleanest one around-period!
Thanks guys. It has been a labor of love for me just as it has been for you young'uns.:wav:
I second that!!
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,029 01-19-2017, 12:53 PM
  Rebuilding used rear leaf springs Crawdad 5 6,484 12-12-2016, 11:54 AM
  Lighted rear view mirror chuzie 6 7,691 06-20-2015, 12:18 AM
  rear main seal snipes243 5 5,011 05-03-2014, 11:45 AM
  stock rear drums scbronco 11 5,786 03-06-2014, 08:09 PM
  Late 70s Cadi rear disc brakes for 77 banjo rear end Crawdad 11 7,572 01-11-2014, 12:26 AM
  77 EB Rear Drive Shaft Dropped - Second time in six months UTFLIWGYA 4 4,131 12-01-2013, 10:38 PM
  Grinding sound from rear end area when driving Crawdad 10 7,841 02-09-2013, 09:33 PM
  '94 351 Rear Main replacement JayT 5 3,805 12-22-2012, 05:34 PM
  5.0 rear main bearing... is it going out??? chuzie 16 8,267 12-18-2012, 04:52 PM
