C4 question
I can get a free c4 from a late model mustang. What needs to happen to get it to mate to the dana 20?
any help?
The car version C4 are usually a case fill design. The bell housing bolts directly to the pump. They tend to have smaller intermediate servos and rarely have hardened inputs. It can be used, but not my choice for strength.
Otherwise to make 2wd version fit a EB you will need an output shaft and an extension housing.
Weren't the car C4 transmissions longer than the Bronco? The Bronco C4 was Bronco only. You have to have the short main shaft to convert a Mustang C4. Right?
Tim
74 Bronco Ranger halfcab
w/toys
The 4wd version has a short output and extension housing that mates to the transfer case. The 2wd has a long slender extension housing that accept the slip yoke driveshaft.
Early BII's had a C5 4wd. C5 is an updated C4 that has an inertia lock up converter. It may be possible to find one of these and swap the bell housing for the 302.
Chasing down a c4 on ebay with the dana 20 from an early bronco. So far 150.00 but it is still early
  Steering shaft Extension Question??? Broncitis 4 4,627 04-17-2015, 02:27 PM
  Exhaust question Casey835 27 14,862 08-16-2013, 06:03 PM
  1991 351W EFI Question Crawdad 4 3,852 03-27-2012, 09:05 AM
  Hard top Question 744x4 5 6,137 09-06-2011, 10:32 PM
Last Post: Mill Knob
  Tire question dixieboyz13 12 7,778 08-25-2011, 01:58 PM
Last Post: ncsubronc
  Fiberglass Dr Insert Question 744x4 5 3,671 08-10-2011, 01:24 PM
Last Post: dixieboyz13
  9" pinion question scbronco 10 5,999 01-07-2011, 08:23 PM
  TTB lift question jdowns67 7 4,690 11-20-2010, 09:36 PM
  v8 water pump question jrshepherd 7 3,945 11-08-2010, 10:18 AM
  90 Bronco TTB Yoke Question 2000F150SAS 2 3,020 02-16-2010, 10:07 PM
