C4 question
I won a C4 on ebay out of an early bronco. It comes with the dana 20 as well. I called the guy and told him to send the tranny but he could keep the dana 20. It will save over $100.00 not to get the dana 20.
The question is
Is there anything off the dana 20 that I need for it to be complete?
carl
It would be wise to get the transfer case also. You will need the input spud shaft and the seal adapter.
Carl where is the tranny?
I would think even if you don't use the D20 it would be worth getting all of it.
Then you could sell or keep it for a spare ect.
just my .02
get em both. is it a t or j shift ? i here t shift is geared lower.
i would like to have the case to rebuild for my bronco. before i say that i should askj if the t is stronger than the j or = in strength ?
call me carl 336-669-6956 i might give you the $100.00 for it.
t-shift=2.46
j-shift=2.34
not alot of difference but enough.
as far as strength...hmmm I don't know
johnpaulgolf Wrote:t-shift=2.46
j-shift=2.34
:beer:
i cant afford a stak right now so i thought i would help carl and buy that one and build it up a little. someone that knows a lot about these should post up the differences and upgrades you can buy for them up in the tech or how to articles section.
this will help your D20
http://www.wildhorses4x4.com/product/dan...a20_T-Case
http://www.wildhorses4x4.com/product/Ext...a20_T-Case
johnpaulgolf Wrote:this will help your D20
according to that i can just build my case and have the same thing.
I've been debating whether or not to go that route or a Stak case. I'd hate to get $1,200 deep and regret not doing a Stak and having 3 speeds. It is nice to know that WH has a sale on the HD output shafts now though.
Get the case carl, you cant have too many spares. Plus, yours has that funky front output yoke(and needs overhaul). A spare rear out put is worth its weight in gold as it is the weak link of that case.
To save the coin of going atlas I would get the lower gear set. I'm not a fan of doubling, the eb has too short a wheel base for it to work well.
  Steering shaft Extension Question??? Broncitis 4 4,686 04-17-2015, 02:27 PM
  Exhaust question Casey835 27 15,124 08-16-2013, 06:03 PM
  1991 351W EFI Question Crawdad 4 3,919 03-27-2012, 09:05 AM
  Hard top Question 744x4 5 6,201 09-06-2011, 10:32 PM
Last Post: Mill Knob
  Tire question dixieboyz13 12 7,876 08-25-2011, 01:58 PM
Last Post: ncsubronc
  Fiberglass Dr Insert Question 744x4 5 3,735 08-10-2011, 01:24 PM
Last Post: dixieboyz13
  9" pinion question scbronco 10 6,110 01-07-2011, 08:23 PM
  TTB lift question jdowns67 7 4,770 11-20-2010, 09:36 PM
  v8 water pump question jrshepherd 7 4,038 11-08-2010, 10:18 AM
  90 Bronco TTB Yoke Question 2000F150SAS 2 3,071 02-16-2010, 10:07 PM
