rear disc brakes***HELP***
ok, I bought the cj7 front rotors for use on the rear full width 9". But, the axle flange does not fit inside the rotor. Do I keep looking for one that fits? Do I cut the axle flange down? Or cut the inside of the rotor out?
I haven't looked to see how much material is there on the rotor, but I'm thinking that would be better. I'll probably break the axle shaft before a rotor breaks. Please help with some thoughts.Chuck
Chuck I did the disk convert that was in BD several issues back. The way mine works is the axle sits on the out side( wheel side ) of the rotor and you use long shank lug studs to go through both the axle and rotor. I'll see if I can find the correct BD issue. HTH
Found it Issue #10, starts on page 66.
later.
66 Rockrawler, 66 RestoMod
[SIGPIC] [/SIGPIC]
That's what I did on the rear 60 too.
I did not think of that. I think Matt wrote that up, but I thought is slide over the studs.
Ya'll are using the studs and wheel to lock the rotor in place? Are the slines on the wheel studs long enough to go through the rotor and secure to the axle flange? Thanks guys,Chuck
I guess if I broke an axle shaft, I would have to reuse the studs on the new shaft...right?
Yes, I wrote the artical on cheap rear disks. You can mount the rotor behind or over the axle flange. If you put it over the flange you must cut the flange down to fit inside the rotor. There is not enough mattrial inside the rotor to cut it down enough. It is easyer to cut some off each.
I have mine with the rotors behind the axle flange. This is not always possible with stock shafts(they have uneven cast on the back side some times).
Since the caliper mount is welded on you can choose where you put the rotor. The only down fall of having it behind is if the rotor needs replacing you have to pull the shaft off.
You should always replace the lug studs when replacing a shaft.
With the rotor on the flange you need longer lug studs.
I can always post more pics of my setup if people would like.
broncomatt Wrote:Yes, I wrote the artical on cheap rear disks. You can mount the rotor behind or over the axle flange. If you put it over the flange you must cut the flange down to fit inside the rotor. There is not enough mattrial inside the rotor to cut it down enough. It is easyer to cut some off each.
that would be helpful Matt. Will the longer studs have longer splines to engage the axle flange from behind?Thanks again,Chuck
I was also currious if a dodge rotor w/5 lug would fit over the flange without issues???
I will set up a tech artical in our section later tonight.
The lug studs with longer splines can be hard to find. I brought the stock
one in and asked them to find me a longer one.
If you cant find a spline section thats longer its ok. Just be sure the splines are holding on the rotor, I have had to weld mine in on some. They spun.
Never tried any other rotors, since the jeep ones had the right lug pattern and a good off set I never looked any farther. I think any rotor could be made to work, but it may take more fabrication time(drilling lug holes, an off set that works, overall diamiter.
will do, I'll statr looking today to see what I can find,Chuck
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 5,149 01-19-2017, 12:53 PM
  Rebuilding used rear leaf springs Crawdad 5 4,291 12-12-2016, 11:54 AM
  Lighted rear view mirror chuzie 6 4,716 06-20-2015, 12:18 AM
  rear main seal snipes243 5 2,982 05-03-2014, 11:45 AM
  stock rear drums scbronco 11 2,586 03-06-2014, 08:09 PM
  77 EB Rear Drive Shaft Dropped - Second time in six months UTFLIWGYA 4 2,037 12-01-2013, 10:38 PM
  Grinding sound from rear end area when driving Crawdad 10 4,479 02-09-2013, 09:33 PM
  5.0 rear main bearing... is it going out??? chuzie 16 3,957 12-18-2012, 04:52 PM
