Fabbing New Rear Shock Mount
11-19-2008, 05:27 PM
very nice...are you making them taller also?
11-19-2008, 05:57 PM
Yep, I made these to fit over the frame @ 2" taller than a stock mount. I'm planning a 1" body lift and will have to notch the seam at the rear fenderwell slightly for fit. I'll put them as far forward as I can to fit longer shocks. A 1/2" GR8 Bolt fits inside of the DOM and should be more than strong enough even though it's in single shear.
Her's some pics of my stock mounts (both sides look this way). It's what 30 years of muck will do to your frame. ![]() ![]() ![]() ![]()
11-19-2008, 06:22 PM
just a thought...if you move them too far forward would it still help on controlling the up/down of the axle? I run mine inboard and never had any bad problems... dont forget to come out tonight!!
11-19-2008, 07:01 PM
You're right...there is a point where too far forward negates that benefits of the shock. I spent a lot of time looking for a solution, and I'll take any advice I can get. I'm running Caddie calipers in the rear and the stock mount location conflicts with the caliper. I looked at inboard and for travel there is no better solution but I don't want the body roll that accompanies it. After prepping the frame, I'm going to test fit these with a single shock to see the best angle vs travel I can get.
1977 Ford Bronco rear ended 9" rebuild | Crawdad | 10 | 5,834 |
01-19-2017, 12:53 PM Last Post: snipes243 |
Rebuilding used rear leaf springs | Crawdad | 5 | 4,689 |
12-12-2016, 11:54 AM Last Post: Crawdad |
Lighted rear view mirror | chuzie | 6 | 5,179 |
06-20-2015, 12:18 AM Last Post: chuzie |
Front shock mounts | snipes243 | 14 | 4,550 |
03-01-2015, 07:51 PM Last Post: scbronco |
rear main seal | snipes243 | 5 | 3,295 |
05-03-2014, 11:45 AM Last Post: chuzie |
stock rear drums | scbronco | 11 | 3,122 |
03-06-2014, 08:09 PM Last Post: Bronco Biff |
Late 70s Cadi rear disc brakes for 77 banjo rear end | Crawdad | 11 | 4,444 |
01-11-2014, 12:26 AM Last Post: Crawdad |
77 EB Rear Drive Shaft Dropped - Second time in six months | UTFLIWGYA | 4 | 2,329 |
12-01-2013, 10:38 PM Last Post: broncomatt |
Grinding sound from rear end area when driving | Crawdad | 10 | 5,006 |
02-09-2013, 09:33 PM Last Post: blazinchuck |
'94 351 Rear Main replacement | JayT | 5 | 2,000 |
12-22-2012, 05:34 PM Last Post: JayT |
