rear axle shims?
are they neccessary? i had a local mechanic tell me that i need them! i have a 3.5 inch lift with 11 pack leaf springs with no blocks. if they are needed what degree shim would be the best?
well, most nice leafs will have that built in. it is necessary-because you have to keep the pinion at the right angle to the transfer case. usually about 1-2 degrees under inline with the driveshaft. with all this said...you might have to install the leafs first then,check how much of a degree shime you will need. I didnt have to run any with my BCBronco 11 leafs,HTH
i have wild horses 11pack with the 3.5 lift built in. theve been on the truck for 6 months and i havent had any trouble. how do i check the the angle?
The driveshaft and the pinion shaft should be in a straigh line. If not the u-joint wil accelerate in part of its rotation and decel on another part. It will wear the joint out doing this. Closer to straight is better. Actually straight is best. Use a tubing bender mag base angle finder. Put it on the top of your drive shaft and then on top of the pinion guard. The two should have the same deflection off "0" or be at the same angle from 90 degrees.
[Image: 2rwp56f.png]
I bought a 4" rear lift from JBG (either 5 or 6 pack) and I asked them if I needed shims and they said they do not run shims on their lifts of that size. I still think I need shims.
I hadn't needed to run shims on any of the 10 or 11 pack springs that I've installed. Can you post pics of what it looks like?
The beauty of a 4-link is being abe to dial in the pinion angle. Smile
broncosbybart Wrote:I hadn't needed to run shims on any of the 10 or 11 pack springs that I've installed. Can you post pics of what it looks like?
ya ill get some in the a.m.
chuzie Wrote:The beauty of a 4-link is being abe to dial in the pinion angle. Smile
bieng you and Chuck are so good at the install you guys can come install the 4link for me!:xyxthumbs: perfect getaway to the mountians.
[Image: DSC_3921640x480.jpg]
[Image: DSC_3920640x480.jpg]
heres a few pics
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 4,802 01-19-2017, 12:53 PM
  Rebuilding used rear leaf springs Crawdad 5 4,094 12-12-2016, 11:54 AM
  Lighted rear view mirror chuzie 6 4,480 06-20-2015, 12:18 AM
  rear main seal snipes243 5 2,853 05-03-2014, 11:45 AM
  stock rear drums scbronco 11 2,379 03-06-2014, 08:09 PM
  Late 70s Cadi rear disc brakes for 77 banjo rear end Crawdad 11 3,631 01-11-2014, 12:26 AM
  77 EB Rear Drive Shaft Dropped - Second time in six months UTFLIWGYA 4 1,914 12-01-2013, 10:38 PM
  Axle Tube Vents Casey835 4 1,316 03-01-2013, 08:20 PM
  Grinding sound from rear end area when driving Crawdad 10 4,288 02-09-2013, 09:33 PM
  '94 351 Rear Main replacement JayT 5 1,520 12-22-2012, 05:34 PM
