5.0/nv3550...engine now dies at stops*help*
Did you try using the new IAC we got for Tommy? The old unit in the garage is junk and considered inop.
Nick, yours does not die because you have a torque converter. Chucks dies because he is manual and pushes in the clutch and the computer / engine is not bouncing back.
IAC is mostly for a cold engine. There is something else going on here. I hope to be back tomorrow night so see ya on Wed.
Which is why I would stick with the slush box. :thefinger:
Just for the heck of it you might try adjusting the screw on the throttle body to hold the butterfly valve open a bit more to see if that makes a diff.
i did try tommys iac...so far i havent had it shut off in 2 days. but you can tell its thinking bout stalling. i have been trying to make it stall but it hasnt. the last thing i did was install a new iac(from tommys) i might unplug the vss and see what it does then
for the record...i aint be trying to get no jeep suckas!
nick...you been so quiet for months, and this is how you come back??? lol
do you have egr valve? it may be hanging up..
EGR is deleted. I am confident it is a sensor issue though.
  Automatic Trans: Why does the engine die as soon as I put it in Park or Neutral???? UTFLIWGYA 6 4,340 05-15-2014, 11:50 AM
Last Post: rbodine
  Engine help snipes243 12 3,881 02-21-2014, 12:06 AM
  Can firing order determine engine block size? 1st Bronco 1 935 08-16-2013, 06:26 PM
  1996 5.8 L Engine Rebuild- Cylinder heads jrshepherd 0 2,715 07-17-2011, 11:13 AM
Last Post: jrshepherd
  Engine Rebuild. 1996 5.8 L jrshepherd 0 1,110 05-05-2011, 02:02 AM
  new engine berg bronco 21 5,005 05-12-2009, 11:38 PM
  Engine build advice cuz1 6 1,862 06-27-2008, 05:35 PM
  engine taching a bit high? bowtieman55 12 4,263 04-01-2008, 08:05 PM
