"whining" rear axle!
Well, I finally got time to break down my rear axle. For a couple of months, whenever I was driving down the road, i heard a "whining" noise. It got louder the faster I went. Well, when I pulled the axle shafts and dropped the 3rd member, this is what i saw. Check out the pics.
Anybody have any idea on what causes the teeth on the gear to become razor sharp??? Confusedcratchhe:
Tha only thing I can think of is pinion depth. I bought everything complete from Randy's R&P. No towing was involved, no 4 wheeling, and I changed the oil at 500 miles for the break in. Notice the little notches on the side of the ring
Your thoughts......
I'm not an expert on ring gear but I have seen this before on a buddys rig.
It was blamed on improper break in. The ring gear got too hot and lost hardness.
After that it's just a matter of time before the tooth face wears away.
That's what makes them look sharp and I can see chips in the picture.
It sounds like you did it right and again, I'm no expert.
I would send those pic's to Randy's and ask them.
I would be interested to see what happened ... keep us posted.
Pinion depth or improper backlash setting. Who set it up for you. I had one do that and it sounded like a train going down the tracks until it failed and lost some teeth. Setting up the rear is a simple process but the proper measuring equipment is a must.
chuzie Wrote:Who set it up for you.
Randy's did. Came complete to my door.
I asked them what causes this and they replied, Improper break in, towing or offraoding. I told them I did none of that. So he cut me a deal on the price and gave me a lifetime warrenty. So If this happens again, all I do is send back the old R&P and I get new ones.
My new ring and pinion and install kit will be here Tues!! Can't wait!!
Well it sucks that happened in the first place but I'm glad you have it sorted out
and will be rolling again next week.
Sounds like this one is the last you will ever pay for. Sweet deal!
For curiosity's sake, what brand gear was it?
bucketobolts Wrote:For curiosity's sake, what brand gear was it?
x2 Confusedcratchhe:
broncomania Wrote:x2 Confusedcratchhe:
YUKON
Looks to be built too tight (I.E. preload), but since they stepped up and took care of it I wouldent worry about it. On some cars I have run it at idle on jack stands to break in a rear end to ensure it was broke in before hard use.
I thought Yukon warrantied their product regardless of vendor.
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,170 01-19-2017, 12:53 PM
  Rebuilding used rear leaf springs Crawdad 5 6,574 12-12-2016, 11:54 AM
  Lighted rear view mirror chuzie 6 7,790 06-20-2015, 12:18 AM
  rear main seal snipes243 5 5,082 05-03-2014, 11:45 AM
  stock rear drums scbronco 11 5,913 03-06-2014, 08:09 PM
  Late 70s Cadi rear disc brakes for 77 banjo rear end Crawdad 11 7,695 01-11-2014, 12:26 AM
  77 EB Rear Drive Shaft Dropped - Second time in six months UTFLIWGYA 4 4,199 12-01-2013, 10:38 PM
  Axle Tube Vents Casey835 4 3,612 03-01-2013, 08:20 PM
Last Post: Casey835
  Grinding sound from rear end area when driving Crawdad 10 7,960 02-09-2013, 09:33 PM
  '94 351 Rear Main replacement JayT 5 3,871 12-22-2012, 05:34 PM
