Rear end vibration
The last few times I've driven at highway speed, I've noticed a rough vibration in the rear end. Any ideas on root cause or troubleshooting sequence? Confusedcratchhe: Thanks in advance :xyxthumbs:
possibly a ujoint in driveshaft. remove the rear shaft put it in 4wd and see if vibration goes away
First stop is driveshaft/ u-joint as firefighter said. See how much movement is in the joint. If it is solid, I do as above to eliminate a shaft imbalance. Beyond that, I would move on to tire balance.
yep, what they said^^^
i had a rear joint(new-1 day old) fall the next day. i noticed a new vibration when it would hit 45mph, stopped to check and found that one of the caps had the needles busted and turned to dust or missing needles.
Could a bad rear wheel bearing cause a vibration? Check your lugs!
Nate
Thanks for the advice. The rear driveshaft and joints are solid. Per Firefighter, I'll remove the rear driveshaft to eliminate the driveline as the root cause. Gotta get this one solved before the drive to Uwharrie! :toothy12:
It is possible for a wheel bearing to cause it, but not likely. If the wheel bearing was to that point, it would be more than just a vibe.
So what is the news? :popc1::popc1::popc1:
chuzie Wrote:It is possible for a wheel bearing to cause it, but not likely. If the wheel bearing was to that point, it would be more than just a vibe.
Jacked up the rear and had my Dad examine the driveshaft. It has a severe wobble at the transfer case joint. It also appears that the tc bearing needs to be replaced because it looks like it's leaking a bit. I'm wondering if the 2" body lift caused an issue with the driveline angle. This is the original driveshaft and it has a lot of play at the rear. What's the rule of thumb on when you need to get an extended shaft? This is the original shaft and it has a lot of vertical play at the rear. Wondering what the best plan of attack would be at this point. Maybe you can give it a look this weekend. :rubeyes: :beer:
[Image: photo-1.jpg]
Body lift won't affect driveline angle. Just suspension lift. I have a stock length rear shaft if u want me to bring to ure I can't use it anymore
I have a 3 1/2" suspension lift and now a 2" body lift. Still ok for the stock shaft?
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,049 01-19-2017, 12:53 PM
  Rebuilding used rear leaf springs Crawdad 5 6,509 12-12-2016, 11:54 AM
  Lighted rear view mirror chuzie 6 7,712 06-20-2015, 12:18 AM
  rear main seal snipes243 5 5,039 05-03-2014, 11:45 AM
  stock rear drums scbronco 11 5,830 03-06-2014, 08:09 PM
  Late 70s Cadi rear disc brakes for 77 banjo rear end Crawdad 11 7,599 01-11-2014, 12:26 AM
  77 EB Rear Drive Shaft Dropped - Second time in six months UTFLIWGYA 4 4,145 12-01-2013, 10:38 PM
  Radius arm bushing cause of grinding/vibration sound? 1st Bronco 7 4,382 09-13-2013, 09:47 AM
  Grinding sound from rear end area when driving Crawdad 10 7,879 02-09-2013, 09:33 PM
  '94 351 Rear Main replacement JayT 5 3,822 12-22-2012, 05:34 PM
