Replacing rear main seal
hey guys, i'm new to this site but have been looking at some of the great pics on here. Here is my problem, i have a 1986 FSB with the 300 six cyl with the C6 4x4 and it needs a new rear main seal REAL BAD! Some shops have given me a quotes from $450 and up, well i dont have that kind of money for this job so i have been wondering how hard is it any way to do myself. I do have experience working with cars and the tools to do it just wondering if you guys would now of anything special i might encounter along the way? Thanks in advance:biggthumpup:
Not real familiar with the 300 6. Do you know if it has a 1 or 2 piece seal?
If it has a one piece seal the tranny will have to come out. If it has a 2 piece you can get by with just pulling the oil pan and rear main cap.
AutoZone says it's a 1 piece seal when you look it up online.
Just pull the transmission & flywheel and the rear main seal is right there :xyxthumbs:
one piece seal..u can pull transfer case & trans or pull the engine....depending on how ur truck is equipt. a/c & so on which way u want to go...
http://www.wheelindixie.com
Yep, its a once piece, it can be a pain in the ass to get in there so just take your time. You may want to make your life easier by buying a tranny adapter for your floor jack....that SOB is heavy.
1996 Bronco, 302, E4OD -- 1977 F100, 300, C4
I agree. Tranny adaptor is a life saver (and a back saver). I promise it is worth the $$ with just the time and frustration it saves.
Confusedcratchhe:well guys i know its been awhile but i just started to work on the bronco and i have run into a problem, i have the transfer case supported with a trans jack and its totaly unbolted and it wont come off. its supposed to slide off and i cant even get it to move. i've even hit with a rubber mallot nothing. any ideas?
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,077 01-19-2017, 12:53 PM
  Rebuilding used rear leaf springs Crawdad 5 6,530 12-12-2016, 11:54 AM
  Lighted rear view mirror chuzie 6 7,734 06-20-2015, 12:18 AM
  rear main seal snipes243 5 5,046 05-03-2014, 11:45 AM
  stock rear drums scbronco 11 5,844 03-06-2014, 08:09 PM
  Late 70s Cadi rear disc brakes for 77 banjo rear end Crawdad 11 7,618 01-11-2014, 12:26 AM
  77 EB Rear Drive Shaft Dropped - Second time in six months UTFLIWGYA 4 4,160 12-01-2013, 10:38 PM
  Grinding sound from rear end area when driving Crawdad 10 7,886 02-09-2013, 09:33 PM
  '94 351 Rear Main replacement JayT 5 3,839 12-22-2012, 05:34 PM
  5.0 rear main bearing... is it going out??? chuzie 16 8,353 12-18-2012, 04:52 PM
