Lincoln rear axle
Ok I happend upon a Lincoln mark rear 9in axle with disks. Can I use any of the brakes on a small bearing rear end?
I think it's a different bolt pattern - 5x4.5 instead of 5x5.5. I think that Carl W (cuz1) ran into this same thing ... let me try to find that posts on here and get the link....
Try this link.. looks like Matt knows more about it, but that was referring to the LTD instead of Lincoln. Hopefully it will work out for you!
The brackets will only fit on an early Big Bearing housing. Not a small and not a medium or Torino style housing.
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 8,958 01-19-2017, 12:53 PM
  Rebuilding used rear leaf springs Crawdad 5 6,448 12-12-2016, 11:54 AM
  Lighted rear view mirror chuzie 6 7,657 06-20-2015, 12:18 AM
  rear main seal snipes243 5 4,996 05-03-2014, 11:45 AM
  stock rear drums scbronco 11 5,756 03-06-2014, 08:09 PM
  Late 70s Cadi rear disc brakes for 77 banjo rear end Crawdad 11 7,550 01-11-2014, 12:26 AM
  77 EB Rear Drive Shaft Dropped - Second time in six months UTFLIWGYA 4 4,103 12-01-2013, 10:38 PM
  Axle Tube Vents Casey835 4 3,541 03-01-2013, 08:20 PM
Last Post: Casey835
  Grinding sound from rear end area when driving Crawdad 10 7,808 02-09-2013, 09:33 PM
  '94 351 Rear Main replacement JayT 5 3,793 12-22-2012, 05:34 PM
