ididit install
try reversing the turn signal wires...i bet right now the run lights in the front are using the "brighter" element..which wont draw enough causing the flasher to work...just a thought
I had the same problem when I was doing my harness. Just trying to remember how I fixed it.
chuzie Wrote:I had the same problem when I was doing my harness. Just trying to remember how I fixed it.
think hard! i tried reversing the wires, but no luck.
The hazard and turn have separate flashers.
Few quick questions...
When was the last time you had turn signals that worked?
Do you have power going to the turn signal flasher from the main power (i.e. fuse panel, 12V source)?
If so,
What color wire do you have going from the turn flasher to the column plug?
It sounds as though you are not getting power to the column from the turn flasher. Respond with the info and we can go from there.
Also, is your horn working? Seems as though you are either missing a circuit or have an earlier setup that does not incorporate a horn relay.
both flashers work
the turn signals worked just like they should before install of the new column
I could not find a wire to match up with the "purple"feed wire from the column
so i temp. hooked it to the 12v horn wire "this could be my problem"
if so what wire do i hook the purple feed wire to?
also if my stock column worked with the before mentionedwires in my previous post why would i need a "new" wire for the new column?
berg bronco Wrote:both flashers work
If you don't have the promblem sovled by tomorrow when I get home I will call you and we will talk and see what we can come up with.
:biggthumpup:
the purple wire may not have anything to do with the turn signal but to be sure I need to know what color wires you have hooked up to the flasher and, in turn, where that wire is hooked into the column.
heres what I got
iididit column centech harness
black-horn-----------------------------yellow-horn
light blue-left front turn-----------------2 light blue-left turn
dark blue-right front turn----------------2 dark blue-right turn
brown-hazard---------------------------brown hazard
purple-turn flasher feed------------------? temp.gray horn power
yellow-left rear turn---------------------yellow-left stop
green-right rear turn--------------------green- right stop
white-brake switch----------------------white-stop switch
My first thought is to follow the line from the turn flasher into the column. I would venture to bet it needs to be connected to the purple wire. I will see if I can pull some other data and trace some diagrams for you to be sure of what is going on. I am sure of one thing, that purple turn feed has no business being connected to the horn.
ya I know:bdent:i was just using it for a power source when I unhook it i only have the hazards
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 2,716 09-19-2018, 02:50 PM
  Southern Rods AC kit install..part 1-heater blazinchuck 22 7,624 03-09-2013, 09:47 PM
  ebay radiator(5.0 conversion) install... blazinchuck 8 5,671 10-15-2012, 10:30 PM
  bushing install ? firefighter2134 2 2,888 08-11-2011, 10:30 PM
  Oil Pressure Guage install location??? Crawdad 3 2,184 04-12-2011, 12:35 PM
  TRO install on my '77 chuzie 9 3,788 12-28-2010, 06:41 PM
  Need help with transfer case install 73Bronc 34 10,626 08-18-2010, 11:45 PM
Last Post: 73Bronc
  Need Speaker Install Ideas 73Bronc 20 5,684 03-19-2010, 09:00 PM
  HELP INSTALL POWER STEERING PBONE2000 3 1,443 12-11-2009, 01:08 PM
  Mini Starter install jrshepherd 2 1,297 11-23-2009, 08:30 PM
Last Post: jrshepherd
