rear axle shims?
Your angle looks a lot better than mine. JBG told me I shouldn't have to lengthen my driveshaft but I think I may need to.
Crawdad Wrote:Your angle looks a lot better than mine. JBG told me I shouldn't have to lengthen my driveshaft but I think I may need to.
i had a stock shaft for a while but if I got her flexed out the shaft would come apart the shaft in the pic is a aftermarket one
Timstrk Wrote:The driveshaft and the pinion shaft should be in a straigh line. If not the u-joint wil accelerate in part of its rotation and decel on another part. It will wear the joint out doing this. Closer to straight is better. Actually straight is best. Use a tubing bender mag base angle finder. Put it on the top of your drive shaft and then on top of the pinion guard. The two should have the same deflection off "0" or be at the same angle from 90 degrees.
just to add to this...perfectly straight is sitting still/not moving...the reason for 1-2* under straight line is for driving or acceleration...the pinion will rotate up-there by-being in a straight line while under powerConfusedmokin:
berg bronco Wrote:[Image: DSC_3921640x480.jpg]
[Image: DSC_3920640x480.jpg]
heres a few pics
i think that looks pretty daayum good...as you accelerate..it will be inline straight:xyxthumbs:
blazinchuck Wrote:i think that looks pretty daayum good...as you accelerate..it will be inline straight:xyxthumbs:
thanks Chuck! i thought it looked close but the local mech. was very worried
i was able to get away from not having to lengthen my driveshaft after my 3.5" lift...but I would think a 5-6" would really need to be lengthened. and we have a drive shaft vender in your area i believe-should get a discount
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 5,466 01-19-2017, 12:53 PM
  Rebuilding used rear leaf springs Crawdad 5 4,492 12-12-2016, 11:54 AM
  Lighted rear view mirror chuzie 6 4,938 06-20-2015, 12:18 AM
  rear main seal snipes243 5 3,123 05-03-2014, 11:45 AM
  stock rear drums scbronco 11 2,824 03-06-2014, 08:09 PM
  Late 70s Cadi rear disc brakes for 77 banjo rear end Crawdad 11 4,140 01-11-2014, 12:26 AM
  77 EB Rear Drive Shaft Dropped - Second time in six months UTFLIWGYA 4 2,170 12-01-2013, 10:38 PM
  Axle Tube Vents Casey835 4 1,548 03-01-2013, 08:20 PM
  Grinding sound from rear end area when driving Crawdad 10 4,706 02-09-2013, 09:33 PM
  '94 351 Rear Main replacement JayT 5 1,813 12-22-2012, 05:34 PM
