'75 Rear end "re-do" Gears, shafts, etc
You know what, screw this. I am wasting too much time trying to save a couple of bucks. I just dropped $485 on a Yukon Grizzly Locker 31 spline. DONE!
from what ive found, the detroits are a h case or a b case, you will need a b case, if you have the 2.891 bearing on your orginal carrier you can use a 3.062 its just a matter of bearing change, i went thru this with my 66, the 3.250 bearings require a aftermarket center housing, the b case does not require the aftermarket housing only the h case, so you will need a b case with a 3.062 bearing, when you buy your install kit it should tell you which bearings are in the kit
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 5,759 01-19-2017, 12:53 PM
  Rebuilding used rear leaf springs Crawdad 5 4,660 12-12-2016, 11:54 AM
  Lighted rear view mirror chuzie 6 5,142 06-20-2015, 12:18 AM
  rear main seal snipes243 5 3,274 05-03-2014, 11:45 AM
  stock rear drums scbronco 11 3,085 03-06-2014, 08:09 PM
  Late 70s Cadi rear disc brakes for 77 banjo rear end Crawdad 11 4,408 01-11-2014, 12:26 AM
  77 EB Rear Drive Shaft Dropped - Second time in six months UTFLIWGYA 4 2,303 12-01-2013, 10:38 PM
  Grinding sound from rear end area when driving Crawdad 10 4,950 02-09-2013, 09:33 PM
  '94 351 Rear Main replacement JayT 5 1,978 12-22-2012, 05:34 PM
  5.0 rear main bearing... is it going out??? chuzie 16 4,677 12-18-2012, 04:52 PM
