PS Pump leak
I guess I wrenched on the fitting to the high pressure side one too many times. It has been leaking at the base of the fitting ever since I pulled it off the other day for maintenance. I even bought a new Aeroquip steel fitting in hopes the old brass fitting was just junk with stretched threads but I still have the leak so the only thing left is to replace the PS pump unless someone knows of a place in town that is willing to re-port the housing with a slightly larger size to replace the old damaged one for less than the $55.00 it is going to cost me to purchase a reman from DAPs.
Oh, in case any of you are scratching your head, I am referring to the '96 Explorer V8 PS pump I am running in my rig, not the canned ham.
you should have bought the new one I found w/reservoir for about $55 @autozone/advance. wasting time and money son...lets get'r done!!!!!
blazinchuck Wrote:you should have bought the new one I found w/reservoir for about $55 @autozone/advance. wasting time and money son...lets get'r done!!!!!
yeah yeah what he said...come on we need the [SIZE="4"]BANANA[/SIZE] ready...that way I have a Bronco thats not a capable as mine!!:hysterical::hysterical:
my setup does not have room for a pump with a integrated reservoir thus the problem.
I have a handful of spare pumps in my shed but they will not work with this setup. What is wrong with wasting money. Afterall, it grows on trees, right?
Can I get my hand on one of those trees? Confusedupergrin:
New pump did not fix the problem. I am still leaking at the pressure side right at the base of the fitting. It shoots out atomized PS fluid. Dangerous stuff around a hot engine. I am pulling the new pump and lines and going straight to Charleston Rubber and Gasket on Monday and asking them WTF!!! I am in the hole $75.00 with them on hoses and additional fittings and now I just dropped $55.00 on a new pump for no damn reason when it was their fitting all along.
Of course they are not liable because I never showed them the pump in the first place and they can only guess what parts will be right for me. How convenient and what a great way to make some $$$.
Ok, I'm done for now. Wife is having contractions.
Someone please correct me if I am wrong, but you CANNOT use rubber o-ring type seals on a high pressure PS type system, right?
My pump came with both a nylon and rubber o-ring and I am a little confused.
Thx.
wrong....confused...yeah sounds about right
Never tried to use that setup, I like the sagina. You can use either nylon or rubber orings, it depends on the fluid you use. The nylon is ment for PS fluid, the rubber is ment for atf.
Not sure what is leaking, but with new parts mated together I would be taking something back. How about some pics.
I figured it out. I will get some pics and make a write-up asap. Let's just say the problem was the freaking stupid FORD fitting and port style!
  water pump v8 302 torque spec jrshepherd 5 5,183 11-13-2010, 10:45 PM
Last Post: Casey835
  v8 water pump question jrshepherd 7 4,059 11-08-2010, 10:18 AM
  Axle Seal Leak.. Again! 73Bronc 13 7,130 10-15-2010, 01:50 PM
  fuel line leak firefighter2134 5 3,295 03-12-2010, 06:46 PM
  Help !!! Caused an exhaust leak johnpaulgolf 10 6,790 09-25-2009, 09:46 AM
  Rear axle leak 73Bronc 8 4,949 03-28-2009, 08:09 AM
Last Post: Barnes 4wd
  EFI Fuel Pump Question SC74 2 2,651 07-11-2008, 10:30 AM
  Power Steering Pump DeTowman 8 6,781 05-14-2008, 09:57 PM
  Power steering pump cuz1 4 2,921 02-20-2008, 06:29 AM
  oil pump drive broncomatt 3 2,736 01-10-2008, 03:20 PM
