351W Rear main seal?
Is it a one piece or 2? Mine seems to be leaking and I am just trying to figure out how long it will take to chane it out. I think the earlier models had a 2 piece, but I am not sure what year it changed.
I am 99% confident it is a one piece which means more work for you.
That's what I figured was going to be the case. Such is life though.
What year model block? I used a late 70's block for my 393W. It is a 2 piece. I'm not exactly sure when the 1 piece became standard, but it is some time in the mid to late 80's.
As far as I know the truck is completly stock, so I would guess the block is an 87' as well. I,m just not exactly sure what year they changed from the 2 piece to the 1 piece.
cavscout Wrote:As far as I know the truck is completly stock, so I would guess the block is an 87' as well. I,m just not exactly sure what year they changed from the 2 piece to the 1 piece.
I believe it changed with Fuel injection....so u should be a one piece!
http://www.wheelindixie.com
This one is still running a carb, but I am about 99% sure it is a one piece. Thanks for the help guys.
Call the parts dept. @ your local Ford store, they can tell you for sure! :xyxthumbs:
I talked to a buddy of mine that has been a ford mech for about 15 years. He does not have much exp on ones this old, but is sure it is a 1 piece. Just more work to get it changed out, no big deal.
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 8,897 01-19-2017, 12:53 PM
  Rebuilding used rear leaf springs Crawdad 5 6,429 12-12-2016, 11:54 AM
  Lighted rear view mirror chuzie 6 7,621 06-20-2015, 12:18 AM
  rear main seal snipes243 5 4,969 05-03-2014, 11:45 AM
  stock rear drums scbronco 11 5,731 03-06-2014, 08:09 PM
  Late 70s Cadi rear disc brakes for 77 banjo rear end Crawdad 11 7,517 01-11-2014, 12:26 AM
  77 EB Rear Drive Shaft Dropped - Second time in six months UTFLIWGYA 4 4,088 12-01-2013, 10:38 PM
  Grinding sound from rear end area when driving Crawdad 10 7,772 02-09-2013, 09:33 PM
  '94 351 Rear Main replacement JayT 5 3,766 12-22-2012, 05:34 PM
  5.0 rear main bearing... is it going out??? chuzie 16 8,197 12-18-2012, 04:52 PM
